It is currently Mon Sep 06, 2010 11:28 am
Post new topic Reply to topic  [ 3 posts ]
 Service 4WD - Does this set a TDC?
Post Service 4WD - Does this set a TDC?
Driving to NJ last night and the message centr is showing Service 4WD. System still changes to 4wd-auto and 4wd high ( didn't try the 4wd low ). Does anyone know if you can scan that for a code as to why it was being displayed? Message wasn't dispalyed again when I started the truck this morning?
BTW, 2005 chevy silverado, 5.3L, push button tranfer case, 71K miles. And before Nick says anything, I'm 99% sure that IT'S NOT THE OPTI!
93Z M6 Black:
The 385 rebuild begins! Supercharged, 3-core front mount intercooler, stage II heads, 3:73's, Street twin clutch, Jethot Longtubes, mufflex 4" catback, Tuned by PCM4LESS! S+W cage, Spohn Suspenion, Yada Yada Yada
1) Build it
2) Race it
3) Break it
4) Repeat!!!
Mon Dec 28, 2009 9:26 am
Post Re: Service 4WD - Does this set a TDC?
The code will be cleared when you shut the truck off... It has to be read with the engine still on.. :screwy
Anyway, I've been reading a lot about this recently.. Cheapest thing to do is remove the connectors ont he t-case, clean 'em, and put dilectric great on them. Also, clean the ground wires for the transfer case on the frame.. (On the Avalanche, they're near a body mount, there's a grouping of like 3 of them)
Other than that, it seems to be the switch ($55), but more often, the encoder/motor ($500) :(
'98 Black T/A M6 car that turns with a baby cam & 243's, now with bling and big stoppie things!
'04 Avalanche 2500 lux-o-tow
'73 5.3 powered Land Cruiser buggy thing on 2-1/2 ton axles & 42's
'00.5 Aprilia RSV1000 - It's red, it's fast, and no, you can't ride it.
Mon Dec 28, 2009 10:45 am
Thanks, I'll check them out.
It's all HOWARDS FAULT!
93Z M6 Black:
1) Build it
2) Race it
3) Break it
4) Repeat!!!
Mon Dec 28, 2009 3:14 pm
